Crank then stall na
Nivek4209
Crank then stall na
Post by Nivek4209 »
Hi all ive just bought a sw20 auto and na it has the 3sge engine
I bought with a fault thst will start for a few seconds and stall
Sometimes you will get 10mins runtime but mostly start to stall with in a few seconds
Upon some google trawling it seems it may be a dodgy igf voltage from the ecu that could be the culprit that cuts injection if no confirmed spark signal hense the stall
Now i have another mr2 auto broken so i thought swapping the ecu id be on a winner but i dont even fire up if i do this
Are there other parts id need to swap over with the ecu
Is there a fix for my current ecu ?
I think my breaker is sw20 rev 1 and the new one is a rev 2 but both are na and both auto
MartinF
Re: Crank then stall na
Post by MartinF »
Have you checked for fault codes?
Blue Lexus RCF
Black MKIV UK Manual Supra
Green MK2 MR2 Tin Top
alsands_mr2
Post by alsands_mr2 »
Rev 1 & Rev 2 auto ECU's are different, open it up to see if you have any leaking capacitors.
The part numbers should be on them.
alsands_mr2
Main Board:
C002 = 63v 47uf - EKZE101ELL470MJC5S or EEU-FC2A470
C004 = 35v 33uf - EEU-FR1V330 or 100ZLJ33M8X11.5
C101 = 10v 100uf - 35ZLH100MEFC6.3X1 or EEU-FR1H101
C105 = 10v 220uf - UHW1H221MPD or EEU-FR1H221
C816 = 50v 10uf - EKZE500ELL100ME07D
C823 = 35v 15uf - EKZE630ELL150ME11D or UPW2A150MPD
Daughter Board:
C894 = 10v 100uf - 35ZLH100MEFC6.3X1 or EEU-FR1H101
C895 = 50v 10uf - EKZE500ELL100ME07D
