The closest rotors to what you need are ST165 celica fronts or SV21-25 camry fronts.
I went with the camry ones as they are
+-0.1mm the same height as MK1b fronts.
I didn't account for pad carrier thickness increase though so that's maybe why ST165 rotors might be the best fit
(they sit 1.5mm closer to outer pad).
So not only would 25mm rotor make it more like 1-2mm space in the inner side, but outer would be more like 4-5mm.
With ST165 it could be 2.5-3.5mm inner, 2.5-3.5mm outer right? Looks like i'll need 3mm aluminium spacers
(they can't be made any thinner; maybe laser/water jet cut from sheet ali)
+ 1.5mm shim between caliper carrier and hub
My installation however is still a work in progress so I have many surprises ahead I guess.
Code: Select all
Dia Thick Height Hub Hat ID Hat OD PCD Holes
AW11 MR2 258 22 42,1 54 131 141 100 4
Camry SV21-25 255 25 42 54 131 141 100 5
Celica ST165 255 25 40,5 54 131 141 100 5
-Height means the dimension between inner rotor friction surface (facing the inner pad) and inner hat surface (where it touches the wheel hub); so it doesn't take the hat's thickness into account
-Source: Brembo diagrams
EDIT: A little footnote.
I haven't found brembo diagram for mk1b so i have nicked mk1a dimensions thinking they are the same with different diameter and thickness only.
If not, all I have just written is a lie!
