On the basis that the stock tyre for the MR2 Turbo is the Yoko A-022, and assuming they set the tyre pressures knowing the stock tyre make and model, I took the assumption that 29/33 was the optimum tyre pressure for the stock Yoko.
With this knowledge, I have been experimenting with the tyre pressures on the Toyo T1-R.
Since it has mega flexi sidewalls and mega-high dry grip, I figured that more pressure wouldn't necessarily make it slippy/slidy like it would a normal tyre.
The results are pretty good actually.
Moved up to 33/36 and the car is a
lot
more
'pointy' at the front, it doesn't take 2 goes to aim at an apex with the car wallowing like a barge
(I call it the MR2 pendulum
- you Toyo owners know what I mean!!), and the sliding is much more progressive, and still very good grip even at the higher pressures.
Just sharing the knowledge guys, don't assume 33/36 is good for you or safe, and I am not advising anyone to go against the Toyota manual.
