I have resumed work on this.
I was looking at the cams the other month and thought they seemed to have a hell of a lot of duration, so took them out and had them checked.
Kent had sent me the wrong profiles.
I was a bit miffed to say the least, as it was all shimmed up and ready to time.
Anyway, they offered to make another pair with the exact same size base circle so I didn't have to re-shim, with the correct profiles I'd asked for.
This took a long time.
They are now done and today I installed them, checked the clearances, which were unchanged, and timed them up.
I also fitted the throttle pot I bought off Ebay a while ago.
I now need to find the cam position Hall effect sensor, which I bought from RS Components, and which I put somewhere so safe even I can't find it
Once found I will work out a way to mount it and get a cam position trigger signal.
Turbo oil drain hose is too short, I either extend it with a join or find a 90 degree hose with longer legs
(preferably the latter).
Then it's the bit I hate, an engine loom.
A bit of finishing on the dry sump piping and it should be pretty well done.
At last!!
The cams should both have
.1363 inch lift at TDC, given it's a horrible belt drive I have got it pretty good.
It'll change as soon as it's run, as the belt will stretch, but it gives me a nice warm feeling to know it was, for a short time, spot on
Photos of today's efforts below.
http://www.chriswilson.tv/cam_timing/cam_timing.html
