Paul @ Kent Car Craft wrote:Arghhhhhhhh!!
I've lost my drivers side corner reflector for the 3rd time!
I lost my driver's side reflector before JAE last year, so bought some smoked ones at JAE, by the time I'd got home, it'd fallen out again!
I bought some new ones which have been on for a while and the other day.
it's gone again
I have a new set, but I'm damned if I'm going to let it happen again!
I'm tempted to silicone it in, but wanted to see if anyone had a better solution?
![Very Happy :D](./images/smilies/icon_biggrin.gif)
Having read about all these people losing their corners, ive tried a little modification on one of mine whilst the car is off the road,
on the back of the reflector there is a pin which clips into a plastic holder
,if you unscrew the pin and replace with a long bolt without a head
,then remove the plastic holder in the car bodywork
,the bolt then goes through the hole and you can put a big washer and nut on
,bit fiddly if you want to change a bulb
,but be honest when was the last time a bulb blew??
Not tried it out yet as the cars on ramps
,ill try and get some pictures if i can
,but the cars in an awkward place
,so you'll just have to picture it in your mind
Ps Do you want to sell the old ones
![Whistle :whistle:](./images/smilies/eusa_whistle.gif)
