Hi Nick,
Have a look in the storage compartments behind each seat.
If there are grills at the front of these storage compartments, then you have the active sound system, which, if I'm right in saying this,
(please correct me anyone if I'm wrong) means you have two subs tucked away in those storage boxes, which in turn, means you have factory fitted amps behind the rear 1/4 pannels
(where the seatbelts are).
Mine is a UK REV 3
& that had the twin sub set up
& yours is 2 years younger than mine, so yours should have it too
I've just installed my stereo
& you'll be very lucky to find an aftermarket amp that will fit behind any of the pannels in the cabin
No point in getting OEM Toyota amps IMHO as if you're going to be installing an amp
& a sub, you may as well get a decent one
As for sub boxes, I do have a spare drivers side box.
It's one of these
& it's just sitting in the livingroom if you're interested
It's for a 10" sub.
PM me if you want to know more.
http://www.auto-acoustics.co.uk/index.a ... ductid=297
I'm currently using the same box as above, but for the passenger side.
I'm thinking of changing that also, but undecided yet, so both could be up for sale
I've got a 10" JL 10Wv3
& it's in a sealed box as the boxes for sealed units are smaller than ported boxes,
& as you know there is not a lot of room in the cabin of an MR2
Size of speaker depends on what music you're into
& how loud you like it really.
I went for a 10"er as I like a variety of music.
Anything from Rock to dance, R
'n' B to hip hop to pop.
A pair of 8"ers would be good as the boxes wouldn't have to be that big.
Some OC members on here even have a pair of 12's behind their lug holes
Again, it's all down to your taste of music.
Where abouts are you based?
Hope this is of any help
Rich
