lockys96 wrote:uprate ure fuel lines too.
Good point, I kind of had
£1000 in mind for complete fuel system so injectors, pump etc.
I guess the lines need to be included here!
mattcambs wrote:For 8500rpm would a lightened flywheel to go with a fully balanced bottom end be recommended?
Uprated clutch?
Yep
- forgot to mention these, was planning on uprated clutch already and probably flywheel too.
The
£250 for a flywheel isn't really significant when it comes to a 5k build
mattcambs wrote:In my opinion 500+ bhp is going to be very peaky in a 2 litre.
Is this for a drag car? If so then surely better to run a GT35 in its comfort zone rather than a GT30 at its limits?
It's currently a 260bhp daily driver but I would have to reconsider that once it's got this motor in it.
It's as much a project for me as anything right now.
Gary ST165 wrote:for nearer 500 hp i would be looking to add the following parts and costs to your list:
thermostatic oil cooler
That's strange, I was discussing an oil cooler today with my housemates.
Not sure if this is overkill or not, what do other ppl do about this?
Gary ST165 wrote:![](./images/smilies/spacer.gif)
oil filter relocation
What's the benefit here?
egt
Yeah
- I like that idea.
Any recomendations of where to get one?
wideband o2
Already have one
a whole array of temp and pressure sensors/senders and alarms to monitor your huge investment.
I think knock sensor, wideband and egt sensors will have this pretty well covered.
I guess oil pressure and/or temp could be added.
Again any recomendations?
budget extra to implement safe shut down
/ retard strategies on the ecu.
for when temps
/ pressures are outside safe parameters
>>> insurance so you don't blow it up!
Shouldn't be a problem with an aftermarket ecu.
Gary ST165 wrote:budget for frequent oil changes
budget for annual top n bottom end engine inspection.
boost
/ power
= increased wear.
expect to replace the big end bearing shells on a yearly basis.
budget for increased car insurance premiums.
I guess so but ongoing
"small" costs so i should be able to handle that.
Gary ST165 wrote:then consider brakes, suspension, transmission running gear hubs etc.
(unless of course you have done this already in preparation.
apologies i haven't followed any of your previous threads))
I'm planning a rev3+ LSD box but if i do decide to go for a big power turbo then will get uprated driveshafts and cv's.
Anything else needed?
Until it's up and running properly and i'm tracking it a lot then i'm not too worried about brakes.
I'm a firm believer of small, well maintained systems when it comes to road brakes.
Rev2+ but not planning on big aftermarket jobbies out of the box.
Yours truly
- isn't that half the fun
This is a really useful thread guys, keep the good info coming
Wingers
