hi mate
they have there own bit of coolant and is totally seperate to the rad.
i have put a mixture of 70% water and 30% coolant
as for the level
, its always good to have a look at it whilst the pump is going
, so when the ignition is on
( ie the pump working
) under the car
, dont worry
, there is very little pressure in there and wont come out
, and then you can see what level it is at
, just top it up if needs be to the top of the tank
as for the display
, the temp gauge is fed through the black pipe going into the overflow on the tank
, and it is a 5volt sensor
( its a pc one
) so i had to convert it from 12v to 5v
but i had a look/search round and never got to the bottom of it
, seems like a power serge knocks it off.
hope this all helps
, look after the 2
, she was/is a real class car
