It appears most commonly used is tein ss.
I dont want to spend silly money, but on the other hand dont want to buy anything rubbish and cheap.
How do tein/d2/k2 compare?
Matt
dawolf wrote:I have cusco's on mine.Any coilovers will give much improved and sharper handling but at the cost of ride comfort and occasional skipping over bumpy roads.
It's nice to have the option of adjusting the height though.
If I was to choose I'd go for a matched shock/spring combo with 30mm drop for road use.
Dan_DCDezign wrote:The Koni's are awesome on the MR2, and the Eibach springs are an excellent choice, whatever dampers you have, but the Koni inserts will only fit<94 rebuildable struts, which are getting fewer, and as you rightly say, Bilstein have discontinued the yellows so getting them is now hard
Dan
www.DCDezign.com
