noticed almost immediately that there was a little patch of oil under it when parked up.
changed the rocker gasket yesterday and now the puddles under the car seem worse after having it running earlier
i'm assuming that the sump gasket
could it be because there is no release for the oil around the rocker cover, more oil is making its way from the sump
just a bit concerning as i spent a good 4 hours yesterday doing the cam cover gasket and now its worse!
](./images/smilies/eusa_wall.gif)
also how hard a job is it to remove the sump and replace the sealant?
i'll most likely drop it into a mates garage next week as sure it will be easier on a ramp.
also there is no real other areas oil could be coming from right
