had some problems getting the main positive wire out of the fuse box, namely there is NOWHERE itll thread through, so i had to get the drill out and pop a hole in the bottom of the fuse box so the wire could pass out to another fuse.
(least i think its a fuse).
its all wired up to a switch that also is spliced into the AIT sensor which i orginally setup for my 7.5inch SPAL fan on my Greddy IC.
.so ive hooked the Rogue fans inline with this and the switch as well.
benifit of the switch, i can run all 3 fans all the time, or i can have them switched off and i go by the AIT sensor readings, so if the sensor sees to high a temp, the fans will automatically come on, best of both worlds really.
excuse the state of the car, REALLY needs a polish and wax.
PS, i couldnt use the supplied engine arm, just wasnt compatable with my TOMS strut brace.
PPS, these do shiff ALOT of air out, am in sure theyll make a decent enough difference when in traffic with regards to heatsoak.
one thing i did notice, was the air thats being pulled, i thought it would be verticle?? instead the air feels like it goes off at an angle facing the rear pilers of the car, this correct???
