Bloody cars.
Just got it back from MOT which it passed, electrics now work.
.dodgy relay.
My SSQV turned up the other day
(I had one a few years back.
.and this new one is different.
.it sits at an angle.
.and has no adjustable bolt on the back for the pistons) so I fitted it, took about 10 minutes.
Set off, car seemed fine.
.slight hiccup/misfire once or twice in 3rd then it was ok.
Gave it some boost on dual carriageway, and it was perfect.
.nice and quick) although the wastegate chatter I had seems to have gone, now the SSQV just flutters alot
(used to run the standard recirc to atmos).
So I start driving home, give it some throttle again, all of 3rd to about 7k revs and a bit of 4th.
.fine.
Pull up at the lights and although it wasn't spluttering, or idling roughly.
.it sounded like a subaru.
.so I set off, still sounding like a subaru
(misfire?) and then it clears as I go into second.
.then with throttle again, same thing when any fair ammount of boost is reached.
Then I limp home with it doing a few more hiccups.
So.
I get home, take the shopping in
(although most of it was mush in the boot).
.reset the ECU with the old fuse trick.
.notice the avc-r was on A setting
(1.2 bar) not B
(1.6) not driven much on A really.
.take it out again and idling was fine, up hill in 3rd with not much boost was fine, infact all conditions seemed fine.
On the way home, I took it up to 1.54bar and it went like a train, smooth as anything.
.then idled fine etc.
No smoke at any point or anything.
.so what's that all about then? ECU learning the SSQV? AVC-R A setting xxxxx up?.
.here are the readings from the Power FC and AVC-R
(Nod????)
inj duty
: 75.3
Ign timing
: 51 deg
Pim volt
: 3924
eng rev
: 670(or 8)7 rpm
speed
: 147 kph
boost
: 1.54 bar
knock
: 58
water temp
: 82 deg
AVC-R
boost
: 1.52
revs
: 6756
throttle
: 75.7%
(hey it's raining)
