orange battery light on dash mr2 turbo rev1
grinny
Post by grinny »
hi could somebody please tell me what the orange battery light is on my dash as it is always on.many thanks ian.
Leon.
Re: orange battery light on dash mr2 turbo rev1
Post by Leon. »
er, that your battery voltage is too low?
Have you got a multimeter? If so measure the voltage across the terminals and report back.
grinny
Post by grinny »
the battery is brand new its reading 12 -12.5 v
Jonx2c
Post by Jonx2c »
I have this, was on when i bought the car battery is fine, its something to do with when you put a UK battery in it causes this problem, i have had loads of people look at it and cant ork it out!
Its a ghost lol!!
grinny
Post by grinny »
thanks for your message,it seems we are both in the same boat because i have fitted a battery that is exide but not sure if it is the correct one,have you had any problems with this light being on or is it ok not to worry about it? once again thanks,ian.
ff_mark
Post by ff_mark »
I assume the voltage goes up to 13.5-14volts when the engines running ?
grinny
Post by grinny »
yeah alternator is putting out 14.5v,
ENSMR2
Post by ENSMR2 »
There should be a sensor that goes into it. If this sensor is not plugged in then you will get that light.
Well this was the case on my old rev1 tubby.
Mark Edwards
Post by Mark Edwards »
ENSMR2 wrote:There should be a sensor that goes into it. If this sensor is not plugged in then you will get that light.
Correct, usually happens when you change the original battery for a new one, no one ever puts the sensor back in, or the new battery can't physically take it. Think you need to just earth it out IIRC.
xxxx, AM TUNING, sbITs
grinny
Post by grinny »
cheers mate what sensor and where do i find it?ps like the jibba jabba but aint got a f-....ing clue what that means lol
Mark Edwards
Should be a screw in sensor, fairly obvious to find normally with a single wire going into it.
grinny
Post by grinny »
cheers mate i l av a look at it 2 nite
Mark Edwards
grinny wrote:cheers mate i l av a look at it 2 nite
I would get you a pic, but my car isn't with me at the moment. :?
grinny
Post by grinny »
thanks mate mine has been garaged till next april be avin some fun then at run what u brung santa pod make sure u go there sometime its the nuts
Mark Edwards
grinny wrote:thanks mate mine has been garaged till next april be avin some fun then at run what u brung santa pod make sure u go there sometime its the nuts
Been loads of times my friend, couldn't get up there this year though unfortunately. :cry:
