how to change plugs with TRC in the way??
iwantoneofthose
Post by iwantoneofthose »
on my rev3 tubby the TRC covers plugs 2&3 making them impossible to get to(i think).
do i have to remove the TRC to change my plugs? or is the a way to do it with it still in?
if i have to remove the TRC is it easyto remove/replace? and how do i do it?
simmo490
Re: how to change plugs with TRC in the way??
Post by simmo490 »
all you need to take off mate is the soft pipe between the IC pipe and the TB, undo the clips and slide it off.
this way you can get the ht leads off and get to the plugs
iwantoneofthose
simmo490 wrote:all you need to take off mate is the soft pipe between the IC pipe and the TB, undo the clips and slide it off.
even with the TRC in the way?? it looks more like its the TRC unit blocking the plugs rather than just the pipe work.. but if i do just have to remove the pipe that will make it so much easier :D
simmo490
Post by simmo490 »
yeh mate, i have been having my plugs in and out quite allot recently and thats all i have been doing, didnt even have to unbolt the HT lead rail (would make it easier though)
Rogue
Post by Rogue »
simmo490 wrote:yeh mate, i have been having my plugs in and out quite allot recently and thats all i have been doing, didnt even have to unbolt the HT lead rail (would make it easier though)
But according to the photo in your profile, you don't have TRC installed.
You WILL need to remove the TRC butterfly section to get to the plugs.
Regards,
Patrick
simmo490
Post by simmo490 »
the photos could be old ones :lol: :lol:
but no i thought this "TC" thingy was the throttle bodie and this is what i was on about, my mistake.
what is this thing people are on about and why aint i got one ??
iwantoneofthose
Regards,
Patrick
o right ok is it a difficult job to do or just undo bolts etc then remove and bolt back on after??
KyzarVS
Post by KyzarVS »
On my Rev2 the TC unit is held on with 4 bolts (13mm socket from memory) - I've taken it off several times to change plugs, I can't see it being possible without.
On mine, the bolts dont seem particularly heavy duty, so I've always tried hard not to do them back up *too* tight, but in 3 years with the car I've never had any problems :P
Mine is also setup so that two are studs with nuts you undo and two are bolts that go into the assembley - I don't know if it's normal or not, but they seem the same design and work fine.
Joe
Rogue
Post by Rogue »
KyzarVS wrote:On my Rev2 the TC unit is held on with 4 bolts (13mm socket from memory)
Toyota don't use 13mm blots anywhere, on any car they produce. 13 is unlucky... (I kid you not)
iwantoneofthose wrote:o right ok is it a difficult job to do or just undo bolts etc then remove and bolt back on after??
Just remove and refit. For those that have't seen traction control, here it is on a revision 2 engine:
...and on a revision 3 engine:
Regards,
Patrick
iwantoneofthose
Regards,
Patrick
thank you :)
mines the rev3 but with a TRD strut brace in the way as well :(
i assume traction control aint that comon then \:D/ or i confused people by calling it TRC
TheRoadWarrior
Post by TheRoadWarrior »
Heres the TRC removed on my rev3 when i changed my plugs, you can see the 4 bolts you need to remove. Theres no gasket to change, just clean it up and bolt back on.
HTH
Daveb
Post by Daveb »
Yeah its a pain in the ar$e. ](*,)
Why couldnt toyota have designed these with inlet manifolds going off to the side. Save these types of problems and hot intake pipes above the hot engine? :roll: Stupid Japanese.
MR2 GT-S Rev3 Red Trackcar
