Doing an oil change
dawolf
Doing an oil change
Post by dawolf »
Hi all. I want to have a go at changing the oil and filter on my '2', seems much cheaper and more satisfying than going to a garage. I'm not very mechanically minded but I'm sure I could do this with some guidance. Could someone plz describe the process and the tools required for this? I presume the car should be jacked up first?
Cheers.
MR2DIE4
Re: Doing an oil change
Post by MR2DIE4 »
jacking up the car is not neccesary.
just lay down on your back and reach out your left side arm, its perfectly doable.
filter can be a hassle to get it off if you don't have the right tools, and if you have a NA this part is mucheasyer with heat shields removed (allthough this in itself is a long jobby)
static
Post by static »
I wrote an article here:
http://www.imoc.co.uk/forums/kb.php?mode=article&k=67
which though basic and covers the turbo car might help. It's easy to do, and my filter came off without any struggles. A search for relating articles brings up a few other handy hints.
