jacking up the car is not neccesary.
just lay down on your back and reach out your left side arm, its perfectly doable.
filter can be a hassle to get it off if you don't have the right tools, and if you have a NA this part is mucheasyer with heat shields removed
(allthough this in itself is a long jobby)
