un1eash wrote:Is it safe to remove the top heat shield? I'm pretty sure ive got a cracked manifold now but cant tell untill the shield is removed and i just know the bolts will shear when i remove them.
Fensport will sell yu a 2nd hand manifold for
£35
+Vat and delivery.
You can remove the heatshield.
I did it.
It did start melting the material found on the engine bay/rear of cab divider.
.the vibration I had on the exhaust turned out the be destroyed manifold/downpipe gaskets.
So
£4 fixed that.
new gaskets and it was sorted.
However if your bolts snap off on the heat sheild then you going to need to go to either Mr.
T or the scrappy for some.
.unless you can buy the from a hardware store.
