Given the rather expensive nature of buying genuine Toyota front wheel bearings, please can anyone recommend any tried and tested good
Thanks in advance
Steve
I mean you could put it up on FB but then it just gets lost in the noise
Race Idiot wrote:I'm interested in looking at alternate topmounts, however I think the only non toyota ones are KYB which are probably the oem supplier for the toyota ones anyway.
stephenj wrote:That's great info Julius, thank you.I'd be interested in a copy of that list if possible?
Such a shame that FB seems to have killed of most forums.IMO FB is nowhere near a decent replacement for forums, especially when it comes to posting and archiving valuable information.
Personally i've avoided posting about technical stuff on FB as there are far too many contrary opinions.
Which list you mean? If all the useful info after 9 years of ownership about aftermarket parts, that will take hours to compile which i might do in the future.
Juliuswws wrote:I currently have blueprint:
Brake discs and pads(all)
Ignition coil
Dizzy cap
Ignition leads
Rear wheel bearing(NSK 43BDW06)
CV boots(inner and outer on one side)
Timing tensioner and idler(Koyo and GMB)
The tensioner(ADT37626) was my luckiest pick so far in regards of branding as it was the same
(Koyo PU355816RR9D) as I would have got it from Toyota, but for the fraction of the price.
All the above parts are great quality.
I have ton of information of cheaper parts and already made a little guide of cheaper good quality timing parts.I was thinking to make a more comprehensive list, but the first guide got absolutely zero interest.
Juliuswws wrote:Race Idiot wrote:I'm interested in looking at alternate topmounts, however I think the only non toyota ones are KYB which are probably the oem supplier for the toyota ones anyway.
Well I have no experience with top mounts, but I would chance a:
Blueprint ADT380502, Japanparts RU-2319 for the front or ADT380505 for the rear.
Are yours worn out or just experimenting?
Race Idiot wrote:Juliuswws wrote:Race Idiot wrote:I'm interested in looking at alternate topmounts, however I think the only non toyota ones are KYB which are probably the oem supplier for the toyota ones anyway.
Neat! Well mine are trd ones, but I've given them quite a hard life on track and also crashing into a barrier on track.I've started hearing them over bumps so they are definitely on the list for replacement sooner rather than later.
Equium Duo wrote:Juliuswws wrote:I currently have blueprint:
Ignition coil
Dizzy cap
Ignition leads
Buddy I would nsap your hand off for that.![]()
Even if it was RAW data for me ot at least comb through.Right now I'm planning ot make a list of parts that i can get fromother sources, such as different bolts from MCMaster Carr.
GMB or even Koyo if you are really lucky.
