http://www.ebay.co.uk/itm/272336131172? ... EBIDX%3AIT
androo007 wrote:235 on a 10" rim? That doesn't sound right
Gazza_DJ wrote:Quoted specs are definitely wrong.
2mad wrote:Gazza_DJ wrote:Quoted specs are definitely wrong.
How do you mean gaz![]()
craig wrote:2mad wrote:Gazza_DJ wrote:Quoted specs are definitely wrong.
Because unless his car has undergone massive surgery on the fronts, those wheels won't fit a MK2.
Plus, the 235 tyres on the rear and the 215s on the front would look mega stretched.
Plus 17x10 rear ET35 would be sticking out past the wheel arch..
Front can be done ive seen it.
rear i was running 245/35/17 et 38 and a 10mm spacer was on the cards with cut arches
id have tried this
Gazza_DJ wrote:Image Replaced With URL For Quote
http://i.ebayimg.com/images/g/zWkAAOSw0 ... -l1600.jpg
That is not what a 215 on a 9J looks like, or what 235 on a 10J looks like.
That is also not how those widths and those offsets would sit on an MR2.
Also, I've never seen a set of those in 17x10J.
Given that they don't actually know the offsets, I would assume that the original stickers are missing.As they are splits, they might not have size stamps as it depends on what barrel they are bolted to.
I bet they are 8J/9J, and they've measured them incorrectly.
id have tried this
Oh, I'm not disagreeing.I've seen 9J on the front of an MR2.
But work is required.
a 17x9 ET35 will not just'fit' a stock MK2.
craig wrote:I was talking about 17x9 ET35 on the front mate![]()
2mad wrote:craig wrote:I was talking about 17x9 ET35 on the front mate![]()
Ok.
wooops
id still try it with spacers
i know it can be done and it looks epic
craig wrote:2mad wrote:craig wrote:I was talking about 17x9 ET35 on the front mate![]()
Ok.
wooops
17x9 ET35 front AND spacers?? I'd love to see that!![]()
