JohnnyC wrote:Could be:
- spoiler gaskets
- rear lights
- grommets at bottom of boot
(under carpet)
I got inside the boot with a torch while the wife sprayed water everywhere- nothing.
Until she sprayed from underneath and a little came through one of the grommets.
If it turns out to be this, just get a replacement grommet, don't be a hobo and put silicone sealant around it.Can't remember how much my grommet was, but knowing Toyota, probably
£10
dazzy wrote:The inner arches into the boot are prone to rotting out, if driven in the wet water can get in.it's worth removing the carpet and looking up into the qtr voids if you haven't already done so.
Hopefully tho it's something basic like the boot seal or grommets.
wenguin wrote:Mine was leaking through two places
- cracked aerial rubber
- a badly sealed alarm sensor in the engine bay
(allowing water to leak down in past the ECU)
fixed both of them with a healthy amount of black rubber from halfords(same stuff people use for tbar leak repairs)
