read its the plug that goes into the ECU however the only diagrams I managed to find on this have not really helped as I am new to all this!
Cheers.
Skywalker wrote:Surely you'll have both ecu's Infront of you.that will tell you all you need.
RyanRs wrote:Skywalker wrote:explain how the coolant leaves the expansion tank and goes back into the coolant system?
Seriously, you don't know the answer to this? and you call yourself a car mechanic
