acf8181 wrote:Both my previous UK rev2's(one t bar, one sunroof) had the two sub system, my import rev3 didnt have it but i retrofitted it.
Wiring isn't there, you need a full cockpit loom from one that has it..
.i then removed the audio wiring from the loom and ran it next to existing car loom.
Only other bits you need are the subs, grills, and autoleads adapter.
Only issue i had was someone had chopped the headunit connectors off my loom, which i've refitted but have developed some interferance..
.so if you can get one thats uncut it'd be much easier.
stuMR2eye wrote:acf8181 wrote:Both my previous UK rev2's(one t bar, one sunroof) had the two sub system, my import rev3 didnt have it but i retrofitted it.
Exactly how I did it.You also need the 3 amplifiers.
I fed the 3 blue/yellow power wires with a direct battery fused link for good clean power.
I also had to repin the adapter to sort out interference as its a known issue on certain ones.
stuMR2eye wrote:It's an earthing issue.![]()
See this thread: http://mr2oc.co.uk/ocforum/viewtopic.php?t=131722
