rev 3 map sensor querry/differences
nuttasie
Post by nuttasie »
Hi, I am going to do a rev1 to 3 tubby ecu conversion. 1 of the parts is a map sensor as opposed to the air flow meter. Have looked on the bay and they seem to look like the turbo pressure sensor by the diag port on my rev1.
Does the rev 3 only have this 1 sensor for boost and what is the difference between the rev 3 and the rev1.
Also Is there any other map sensor i can use as the second hand prices am stupid compared to when i was going to do this years ago.
thanks
Peter Gidden
Re: rev 3 map sensor querry/differences
Post by Peter Gidden »
You need to use an OEM Rev3 MAP sensor. They've never been cheap S/H.
nuttasie
Post by nuttasie »
Peter Gidden - SBITS wrote:You need to use an OEM Rev3 MAP sensor. They've never been cheap S/H.
thanks,is there only the one sensor on the rev3. don't want to buy one then find out got the wrong one through wrong item description etc.is the rev also located at the diag port bracket?
Peter Gidden
Just one sensor for Rev3-5. Purple/silver label.
nuttasie
Post by nuttasie »
Slightly/largely off topic. I got a mapecu(performance-motor-research)ages ago when was going to just bin the afm. It has its own map sensor in order to bin the afm. Any idea wheither it might be compatable as a substitute as never planned on using with a rev3 ecu but if I can save a few bob using something i already got :lol:
Peter Gidden
nuttasie wrote:Slightly/largely off topic. I got a mapecu(performance-motor-research)ages ago when was going to just bin the afm. It has its own map sensor in order to bin the afm. Any idea wheither it might be compatable as a substitue as never planned on using with a rev3 ecu but if it can save a few bob using something i already got :lol:
Doubt it very much. OEM sensor is 2.5 bar which is highly unusual.
As i said, use the OEM sensor.
SonicSW20
Post by SonicSW20 »
What's the advantage of switching to a MAP from an AFM?
nuttasie
Post by nuttasie »
Ok,thanks for your time.
sie
nuttasie
Post by nuttasie »
Well for me its getting rid of another item to not worry about going wonky lol , but to alot its about getting rid of a restriction depending on power goal i believe.
SonicSW20
Post by SonicSW20 »
MR2's are hotwire AFM, aren't they? Is it that much of a restriction? I'm not saying it's a bad idea (I wouldn't know), I'm just curious.
bobhatton
Post by bobhatton »
Gazza_DJ wrote:MR2's are hotwire AFM, aren't they? Is it that much of a restriction? I'm not saying it's a bad idea (I wouldn't know), I'm just curious.
No they are not hot wire.
fingers99
Post by fingers99 »
Gazza_DJ wrote:What's the advantage of switching to a MAP from an AFM?
It's simpler, cheaper to produce, use one part rather than two, etc. At 400+ bhp there are said to be flow advantages.
It's a flap type AFM. not hot wire.
SonicSW20
Post by SonicSW20 »
Ahh, fair, I'm sure I read somewhere they were hotwire!
