Do the small wind deflectors mounted on the front wheel arch make any noticeable difference?
Does anyone have a photo of how they are mounted, do they just bolt to the wheel arch liner?
Front Wheel Arch Wind Deflectors
Re: Front Wheel Arch Wind Deflectors
unless you have rev5 arch liners, you need to drill/screw into them, some even recommend making a plate to sit behind the liner to support them as they are going to get quite a bit of force against them.
I've just fitted new wheel arch liners on the front, stupidly I should have ordered the rev5 ones. The car had the wind deflectors fitted before with 2 small angle brackets and holes drilled into the old liners, I'm just considering whether I should refit them or leave them off. If they do make a noticeable difference to front end lift then I'll make some new brackets and refit them.
From what i've heard yes they make a worthwhile difference.
id be interested to see pics of your setup? as im sure others would as well for a DIY effort.
i wanted to fit some for a while, just havent go around to it.
toyota saw to fit them as well as the rev5 spoiler, so i assume they do have benefits otherwise why go to the bother.
I've seen a good few modern cars with the same setup.
From what I've read, it's to slow down/re-direct incoming air away from the front of the tyres which can cause vibration at speed
I think gavsdavs fitted some recently IIRC
I just fitted them through standard arch liners and into the end of the splitter.
Fitted fine, no deflection. Ball ache to install that way though.
JD wrote:I think gavsdavs fitted some recently IIRC
Yep - probably help a little with economy, stability at speed.
Helped a bit...
Time to paint yer Rotas, Gav?
I like the bashed up look. Street, innit bruv.
replica speed flaps? or toyota?
costs?
costs?
Real, eBay, mr2ben. They didn't come with the backing plates which you probably want as they are moulded to the inner arch.
gavsdavs wrote:I like the bashed up look. Street, innit bruv.
Oh I dunno - a bit of bling might go down well on the mean streets of south London.
I like working in a field where I always have photoshop to hand.
gavsdavs wrote:Real, eBay, mr2ben. They didn't come with the backing plates which you probably want as they are moulded to the inner arch.
Easy enough to make one up though?
Can you Photoshop a land rover wheel on there. Cos that's what I'd like to be using in town. /70 profile tyres, the works....
Sorry for the rush job - looks like you might need to do some work, to make them fit, though
JD wrote:Sorry for the rush job - looks like you might need to do some work, to make them fit, though
Image Replaced With URL For Quote http://i.imgur.com/7vk3Bwd.jpg
LMAO
