I know this has been done a 1000 times but I'm considering the above swap.
ENGINE LOOM
AFM
TURBO
COIL PACK
WALBRO FUEL PUMP
INTER COOLER
PIPE WORK
ECU
SUB FRAME
DRIVE SHAFTS
REAR BRAKES
BLISTEIN SUSPENSION
EXHAUST
Is there anything else I need? I will be servicing the engine before it goes in with new plugs, belts, leads, filters etc and am hoping to do it in under a week.
Any ideas how long it takes to remove an engine for an SW20?
Things I should look out for?
I have seen the how to thread that gets posted around which is helpful but is a rev2 to rev2 swap so I'm assuming there are minor differences!
Will the loom be plug and play into the passenger footwell? This is another query I have.
Cheers Ben
