Reluctantly selling my Rev 2 Turbo in astral Black
Imported by Platignum Securities on 13/08/03
Car was speedo converted at date of import with 65210km
Speedo now showing 106500 so has covered roughly 80 thou miles
Alarm
Does have a little history including work undertaken by The garage that shall not be mentioned
Got 3 toyota invoices for parts
2 rolling road graphs from AJEC Racing
Showing 258.4 hp
After 3 Months of owning the car it became clear that it was not running correctly and had a lot of crank pressure so the head was removed and the engine was found to be damaged beyond repair
So the car has under gone a complete engine rebuild consiting of
Rev2 block, crank, rods
Rev2 head
Full Toyota gasket set
Rev3 steel headgasket
Gates timing belt kit and tensioner
New water pump and thermostats
And rebuilt by TB Auto Engineering
Rebuilt ct26, adjustable actuator set at 0.8bar
Fully replaced ignition system inc coil, igniter, dizzy cap, rotor arm
NJK iridium plugs
Full compression test done with 170-188 across all chambers
This engine is still being run in has only covered 160miles since the rebuild
Previous Modifications inc
HKS Air Filter
Intercooler and hard pipe kit
Full custom exhaust by powerflow
Mbc not on car at the moment due to running in
Blitz 52mm boost gauge
Apexi dumpvalve setup to recirc
Tom's C7R 2 peice wheels 16" 8j front 9j rear these could do with a refurb
Rev3 rear light conversion
Car does have the usual age related marks and has a slight crack in the paint on the drivers wing were the light has rubbed the wing,
The car will be supplied with 12months Mot and 6months tax
I'm asking
Any questions just ask I'm only selling as my wife has recently told me we are expecting our second child so the toy has to go
Few more pics inc the underside
Thanks guys
I'm in no rush to sell this car so please don't make silly offers
Any inspection welcome
Also forgot to mention that it has a Recaro Speed driver seat with slight wear
