blitz nur spec r exhaust for the mr2 turbo with baffle cause alot backpressure
QUOC2008
Post by QUOC2008 »
blitz nur spec r exhaust for the mr2 turbo with baffle does it cause much backpressure or if any at all... i heard it can cause alot and make the engine over heat???
MR2 REV 3 TURBO 450BHP
3000GT VR4 TT 500BHP
EVO X FQ360
Hez
Re: blitz nur spec r exhaust for the mr2 turbo with baffle cause alot backpressure
Post by Hez »
I would be careful with a bung on a blitz nur spec, it could create too much back pressure and it can cause the engine to run backwards.
Nic
Post by Nic »
Fitting an exhaust bung has a noticeable effect on performance, it won't make the engine overheat as such but it will increase the exhaust gas temperatures.
I've fitted an extra silencer on my Blitz NUR R, it has quietened it down with minimal effect on performance http://www.imoc.co.uk/forums/viewtopic.php?t=172721
Nic
[email protected]
MR2 Rev 3 GT Turbo
Draven
Post by Draven »
I'd say the effect is minor. It will cause excess back pressure which will create a drop in performance. But it also quietens down the car.
I run my Nur without a bung but then Its only a weekend car not sure i'd want to use it daily.
andrew77
Post by andrew77 »
Nur spec and Bung.... scrap that... run without!! use mine as a daily and love it!!! :twisted:
Draven
Post by Draven »
andrew77 wrote:Nur spec and Bung.... scrap that... run without!! use mine as a daily and love it!!! :twisted:
Guessing you don't do lots of motorway miles then
JD
Post by JD »
Hez wrote:I would be careful with a bung on a blitz nur spec, it could create too much back pressure and it can cause the engine to run backwards.
I've just done 1500 miles (motorway/country roads) on the Lemans trip with Nur Spec-R, Berk de-cat and no bung. Not once did I feel it was too droning in the cabin.
Sounded epic in the tunnels though. :twisted:
I wouldn't bother with a bung. Makes barely any difference to how loud the exhaust is, and it'll be more restrictive.
andrew77
Post by andrew77 »
Dual carriageway everyday but doesn't really bother me unless I'm sitting at the same speed for ages , just open the windows and enjoy
\:D/ bung is always in the boot should I need a break if it's several hours of driving ha!
Tedtiler
Post by Tedtiler »
I did some testing of my nur spec with/without bung. Definitely the bung held the car back slightly.
Found the car too loud for my liking without the bung. Neighbours not happy.
I ended up cutting half of the pipe on the inner side of the bung and found that to be a compromise I could live with. How half the bung pipe flows better than the full one is beyond my reasoning but it does.
QUOC2008
Post by QUOC2008 »
can anything be done to the baffle to make the exhaust quieter... i was thinking replace the small insert pipe on the baffle to a larger one or same diameter of the exit that fits perfectly around the exit of the tail inside would this help...
EVO X FQ360
Race Idiot
Post by Race Idiot »
Instead of trying to make a loud exhaust quieter with a bung, why not buy a quieter exhaust. Either that or get a silencer welded in somewhere.
QUOC2008
Post by QUOC2008 »
but the baffle really works... its perfect noise level with the baffle inserted... but then if i what the it louder i can just remove it so that why i want to keep it.
i had a look at other exhaust but the only other one that has the same performance is the hks hi power, but this exhaust rusts real bad as its not stainless steel
EVO X FQ360
Peter Gidden
Post by Peter Gidden »
QUOC2008 wrote:i had a look at other exhaust but the only other one that has the same performance is the hks hi power, but this exhaust rusts real bad as its not stainless steel
The HKS is not the only other exhaust that is known to be very free-flowing.
thomp1983
Post by thomp1983 »
Go to a decent exhaust place and get them to make you a bung that meets your needs I had one made for my old gt4
Peter Gidden
QUOC2008 wrote:but the baffle really works... its perfect noise level with the baffle inserted... but then if i what the it louder i can just remove it so that why i want to keep it.
It's not a baffle, it's a bung.
Any bung will decrease noise level and increase back pressure.
JD
Post by JD »
Yeah, and they also did a SS version which pops up for sale every so often, usually quite expensive, though.
I'll say it again; the full-fat Kakimoto is the best sounding exhaust for mk2 (IMO) and the Apexi GT spec (or N1) isn't far behind.
The Buddy Club is just stupid - you will go deaf and cause structural damage to buildings.
The Blitz Nur-spec R is vastly overrated (IMHO).
HKS silent hi-power (SS) seems to be designed using magic that makes it the best of both worlds.
I haven't had my A'pexi noise-tested yet but I'm fairly confident that it will scrape by the 105db static limit at Blyton.
Peter Gidden
OP hasn't actually said he wants to change his exhaust. :?
Nur Spec isn't over-rated imo, it's a well built quality exhaust that sounds awesome. Each to their own mind
androo007
Post by androo007 »
I see no one really mentions the eBay specials..... are they best avoided?
