New solid base shifter bush from the USA
Base out with old rubber base bush
Old vs new
in and lined up
All done with bolts all done up
MartinF wrote:I can't see how they will firm up the feel of the shifter
Peter Gidden - SBITS wrote:My experience entirely.![]()
Not an ounce of difference.
Look pretty though.
MartinF wrote:I can't see how they will firm up the feel of the shifter, just transfer more noise and vibration from the tunnel to the shifter.
RyanRs wrote:Skywalker wrote:explain how the coolant leaves the expansion tank and goes back into the coolant system?
Seriously, you don't know the answer to this? and you call yourself a car mechanic
jimGTS wrote:where on earth you get them for a 10er?
im sure there is some small positives to this mod.
on a shift, you will be yanking on the plate, that plate will move around a fraction due to the rubber bush, how much it moves though is anyones guess and if you would notice the difference
takman wrote:dont knock it unless you've tried it..
like OP said, its an accumulation of changes that make the difference.
MartinF wrote:takman wrote:dont knock it unless you've tried it..
Those Toyota engineers really were crap at their jobs![]()
