Solid Shift Base Bush install
Mr Bognor
Post by Mr Bognor »
Just a quick update for anyone thinking of doing this .
New solid base shifter bush from the USA
Base out with old rubber base bush
Old vs new
in and lined up
All done with bolts all done up .
markstevieandmads
Re: Solid Shift Base Bush install
Post by markstevieandmads »
And what does these actually do?
Mr Bognor
Post by Mr Bognor »
replaces the soft rubber bushings that support the shifter base firming up the feel of the shifter
MartinF
Post by MartinF »
I can't see how they will firm up the feel of the shifter, just transfer more noise and vibration from the tunnel to the shifter.
Blue Lexus RCF
Black MKIV UK Manual Supra
Green MK2 MR2 Tin Top
Peter Gidden
Post by Peter Gidden »
MartinF wrote:I can't see how they will firm up the feel of the shifter
My experience entirely. Not an ounce of difference. Look pretty though.
MR2 Rich
Post by MR2 Rich »
What's wrong with just buying the original ones from Toyota?
No 2 :(
JohnnyC
Post by JohnnyC »
Peter Gidden - SBITS wrote:My experience entirely. Not an ounce of difference. Look pretty though.
^^^this
markstevieandmads
MartinF wrote:I can't see how they will firm up the feel of the shifter, just transfer more noise and vibration from the tunnel to the shifter.
Exactly - that's why I asked.
rev3turbo
Post by rev3turbo »
whats the point in firming up a plate that doesnt move anyway? :lol:
it could be secured by glue for all that it matters, none.
Mr Bognor
Post by Mr Bognor »
For £ 10 its not going to break the bank and gave me something to do at the week end :)
madbasshunter
Post by madbasshunter »
As he said #-o and I have enough vibration in the car as it is
RyanRs wrote:
Skywalker wrote:explain how the coolant leaves the expansion tank and goes back into the coolant system?
Seriously , you don't know the answer to this? and you call yourself a car mechanic :shock:
jimGTS
Post by jimGTS »
where on earth you get them for a 10er?
im sure there is some small positives to this mod.
on a shift, you will be yanking on the plate, that plate will move around a fraction due to the rubber bush, how much it moves though is anyones guess and if you would notice the difference
Mr Bognor
Post by Mr Bognor »
Does feel better but then i have changed the cube , shift bush and gear oil but it all helps .
Alan
jimGTS wrote:where on earth you get them for a 10er?
takman
Post by takman »
dont knock it unless you've tried it....
like OP said, its an accumulation of changes that make the difference.
MartinF
Post by MartinF »
takman wrote:dont knock it unless you've tried it....
Those Toyota engineers really were crap at their jobs :roll:
Blue Lexus RCF
takman
Post by takman »
Yes I understand your point. But we are talking Standard vs. Performance.
With that thinking, nobody should modify their car at all then? Don't fit polyurethane bushings, better clutch etc....right?
