Besides the risk of a ticket for basically nothing, you don't need to have your headlights on for your fogs as well, just your sidelights on, then you can turn your fogs on
(if you really want to)
And anyway, you can switch the front foglights on when only the sidelights are on.
It's the rear foglight(s) that require the headlights be on.
True at least for UK spec mk2's.
And you can still turn your rear fogs on without main beams, you just need to turn the front one's on first before the rears will work, then you can turn the fronts off and the rears will stay on, but having the headlights on means you can switch the rear fogs on without having to do the fronts first.
Or at least that's how my UK Rev 5 works.
But what do you think to this, wiring the front fogs into your full beams? I mean you only ever use them when the road in front is clear or to flash someone for a split second, so why not fogs and full beams? I usually use both together if I'm driving on a quiet road at night and find that the fogs really illuminate the road right in front and to the side more than my full beams can, purely because of placement and beam pattern
