Right.
The 2 is currently running a CT20b with an aftermarket FORGE actuator of which is not working.
I have another new aftermarket Turbo Dynamics but dont have the correct end piece so i am going back and fitting the standard toyota actuator.
The standard actuator has x2 pipes coming from the top of the housing, My FORGE/Turbo Dynamics only have x1 connection from the top.
Do i only use one of the two standard conections on the toyota actuator and then blank one of them off??
The car is running a Gizzmo boost controller if this info helps?.
Any pics/info would be great thanks.
Best regards
Craig
