Rev 3 engine
walbro fuel pump
de cat
blitz nur spec
big cone intake
MBC running 1bar
SSQV
4ndee wrote:are the regulators removable/replaceable?
4ndee wrote:I checked today to see if it was leaking fuel past on the regulator and its not, i need to check the fuel pressure though.
Peter Gidden - SBITS wrote:4ndee wrote:are the regulators removable/replaceable?
Yes.![]()
Look on the end of the fuel rail.
Thought you worked in a garage?
I thought the regulator was intergrated into the fuel rail, ive never seen anyone replace one before on these engines
4ndee wrote:Peter Gidden - SBITS wrote:4ndee wrote:are the regulators removable/replaceable?
Yes.![]()
I have 2 lambda sensors one is oe and the other isnt and i have swapped both them around and still smokes either way.One looks more rich than the other but i cant believe they are both faulty.
[url]http://i867.photobucket.com/albums/ab235/4ndee/20131019_153024_zpsfbacfb11.jpg
[/URL]
im currently looking for a wideband
4ndee wrote:so im wondering if the ecu is damaged,
