Stubborn Ball joint seperation
racingrepairs
Post by racingrepairs »
I am having a hell of a job separating the ball joints from the lower arms on my newly acquired uk na rev3.
Iirc i used to smack the lower arm with a lump hammer until the little beggars separated. Unfortunately after adopting my technique i have met my old pall Failure :(
Any suggestions please before i throw a hand grenade in the car? :lol:
rev3turbo
Re: Stubborn Ball joint seperation
Post by rev3turbo »
using 2 hammers, one either side can work
Or a ball joing seperator, I prefer the type that screws down applying pressure, then a hit with a hammer
then theres the lever type ball joint splitter, but I dont like these as they tend to damage the rubber boots
Slarty
Post by Slarty »
Use something along the lines of this:
http://www.ebay.co.uk/itm/SYKES-PICKAVA ... 0659129618
racingrepairs
Hum, tried all except the middle one... Looks like I may be purchasing a new tool tomorrow :)
Slarty
Post by Slarty »
Oh, when using the one I've suggested, screw the bolt down until it's REALLY tight, and then tap the top "finger" with a hammer. The load plus the small shock will cause the joint to pop free and save you from damaged knuckles if you try to split the joint just by tightening the bolt.
racingrepairs
In all honesty I tried a 2 leg puller in conjunction with my breaker bar bit it broke :(
racingrepairs
Ball joint fork was useless and yes, destroyed the dust cap..
racingrepairs
Slarty wrote:Use something along the lines of this:
just found that my local Machine Mart sell these for £8
oooo new toys
Thank you :thumleft:
b16hbg
Post by b16hbg »
Try levering down on the arm with a long bar/screwdriver and then hit the bottom of the hub where pin of the ball joint sits. Should eventually crack.
shinny
Post by shinny »
I've had alot of trouble replacing ball joints on my rev3 turbo... both times I ended up removing the lower arm from the car, heating the end with a blow torch repeatedly and smacking the joint out with a lump hammer!
racingrepairs
Rum, yes maybe stubborn was the incorrect definition :)
Slarty
Post by Slarty »
That's why the machine mart one was £8 and the SP one was £25 #-o
racingrepairs
It was forged... Did it in the end with one they replaced it with :)
Was a stubborn one Thow!
Slarty
Post by Slarty »
Well I guess that's the main thing.
My SP one is a beast, had it for about 18 years or so now and it's not even so much as blinked at any ball joint I've used it on. Only minor issue was that I had to grind the jaws open slightly to accomodate bigger joints but that hasn't even weakend it!
4ndee
Post by 4ndee »
These are AMAZING for mr2 ball joints
John145
Post by John145 »
I had this issue, soaking with WD40 and Halfords releasing agent several times, allowing to soak for several hours and repeating then popped straight out with a splitter. I spent several hours previously trying to get the b'stard out!
stuMR2lee
Post by stuMR2lee »
That's exactly what I did with a cheap Machine Mart separator.
Got a Franklin one in the end. What a difference:
http://www.ebay.co.uk/itm/Franklin-Ball ... 20d2501514
bobhatton
Post by bobhatton »
racingrepairs wrote:It was forged... Did it in the end with one they replaced it with :)
Yes but forged in China #-o
SySanguinary
Post by SySanguinary »
Fire. I always resort to fire. :thumleft:
