Body filler made of titanium!
moscoworbust
Post by moscoworbust »
Hi,
I've sanded down my front bumper for paint, it's 99% perfect.
But on the front there was some filler which needs flattening, a bad job by the previous owner.
But this filler is made of steel or something, it literally won't sand. Anyone experienced this before?
AManInDandism
Re: Body filler made of titanium!
Post by AManInDandism »
You can get metallised body filler, but you should still be able to sand it.
moscoworbust
I used 80/320/400/, everything, it just seems so slide over it.
It's f'in weird.
It's a beige yellow colour.
AManInDandism
Maybe need something more course?
moscoworbust
Nope.
I was just wondering if anyone knew what it was. Might be useful to know.
It's at least 100 times harder than P38.
An electric sander might cut through it.
I guess I'll just go at it again this evening.
AManInDandism
Good luck!
Steve-O 2007
Post by Steve-O 2007 »
Hammer and a Chisel???
moscoworbust
Steve-O 2007 wrote:Hammer and a Chisel???
I am certainly tempted!
RST
Post by RST »
It could be epoxy repair resin mixed in with the likes of talk etc. I've made that mistake before, sometimes Araldite etc will set harder than rock if you combine the filler right. Otherwise it should sand off if you use plenty of water and soap as a lube.
