It sounds like the upper mount bearings are seized, it's a common problem and as you say will cause the springs to turn, which is the sound you will hear/feel.
You could try cleaning/freeing up the bearings but more often than not they'll need replacing.
I'd also check the spring cups for corrosion
- mine were in a shocking state
- dampers for leaks and take the opportunity to fit new damper boots and bump stops.
I've recently overhauled everything on mine, I sourced the upper mounts, boots and bump stops from GTSchris here:
http://www.gtschris.com/store/comersus_ ... ategory=59 and new Bilstein dampers and spring cups from Toyota.
