I need some help.
dont want to spend mad money but reasonable amount is ok.
i have most of the bits for conversion apart from the a rev 3 turbo ecu/engine loom, rev 3 turbo fuel pump resistor and the coil for the rev turbo igniter.
anyways need to know if any 1 can do the job.
these are all the Rev3 turbo item i have
Map sensor
IAT sensor
MAT sensor
4 wire o2 sensor
water temp sensor
Knock sensor
Igniter(with out coil, but im not sure if my rev 2 turbo coil is fine to re-use)
Injectors
Power fc ecu
ST205 Ecu
Walbro 255 fuel pump
As of now these are the mods the car has got.
Forged pistons
cometic head gasket
ARP head bolts
Turbo Technics stage 1 hybrid turbo
Greddy SMIC
Full Japspeed exsuast system and de-cat down pipe
Induction kit
Greddy boost controller
Please help me convert my car and make me faster
