anyone in bedfrodshire want to fit cambelt
please delete.
Re: anyone in bedfrodshire want to fit cambelt
You'll find it tricky finding someone who will do it
"for a bit of cash" in your driveway.
Firstly unless they're very lucky they'll need a compressor to undo the crankshaft bolt
- it not unusual to need 300-400ftlbs of torque to undo.
Secondly it's a 5-6 hour job, so expect to pay couple of hundred quid for a thorough job.
Can always use the starter motor to undo the crankshaft bolt if she is a bit tight
Agree that you should get it done properly, I did my own and it was hard work.
My compressor is not man enough for the crank shaft pulley on most cars so I have to use the wife, the brakes and a breaker bar with a pole on the end.
