Why are these cars never easily fixed?!
Hi guys, as you can probably tell, I'm getting fed up with this heap of sh*t. Replaced plugs, misfire still present, replaced cap and arm, misfire still present, replaced ht leads, misfire better but still present! Am I really looking at replacing the whole ignition system just to fix a stupid little high boost misfire!??
Re: Why are these cars never easily fixed?!
where is the miss fire ? low revs high revs ?
Starts at 4k ish! On full acceleration. I'm gonna have to replace the coil I think
I could´nt fix my high boost missfire problem. So I went MSD.
Still works perfect passed 600hp
I've gone through the same thing.
Fitting a late igniter from a Lexus and a new coil in the morning, will let you know how it goes. Nothing else left to replace
You drive. You drive. I think there's something wrong with me.
I don't think it's an ecu fault, I just think the ignition system on these are xxxx!
Well i've replaced:
HT Leads
Dizzy Cap
Plugs
Rotor Arm
Same probs, missfire at high rpm and idle or when damp/wet weather.
Coil pack was split, sealed with silicone, same probs.
Igniter is corroded so ordered a very clean later Lexus version.
Along with fitting the coil and igniter, I'm fitting a CT20b turbo in the morning.
Hopefully by dinner I'll have a smoke free smooth running turbo
........................but then again
HT Leads
Dizzy Cap
Plugs
Rotor Arm
New turbo??! Why? I'm certain mine has gotta be sorted by a coil. Is the igniter the same as an amplifier?
Fitting a turbo because at the minute it has a CT26 fitted which has just started smoking and it's a good time to fit the correct CT20b
These are the ignition components I'm fitting, both above each other under the fuse box in the engine bay.
About £60 for the coil and igniter.
Where from dude? I've found a coil for 45 quid.
i had misfire only in extreme rain conditions. replaced loads but replacing the coil pack fixed it i think.
I had the same thing all but a month ago and it was the ignitor they crack and break down underload you can get them from camskill.
http://www.camskill.co.uk/m5b0s606p1087 ... Turbo_SW20
Daz
Daz
Found it finally! Got a tracking line on the coil on the inside where the ht lead connects, left it soaking in oil for the night, order a new on as well from camskill, probably!
