nath severs wrote:hi does anyone know of any pre made and drills plates which can be welded to the chassis then the antiroll roll bar to the plates,ive just ripped another arb from the chassis
,cheers
hi thanks for replying this time is was a 91 import with a gen 3 motor in itPeter Gidden - SBITS wrote:Give us a bit more info.
Rev1s had a well-known issue with the chassis cracking between ARB mounting holes, but those areas were strengthened in later cars.
What Revision?What size bar?
I would have thought any competent welder could strengthen the area properly for you.
