anti roll bar
nath severs
anti roll bar
Post by nath severs »
hi does anyone know of any pre made and drills plates which can be welded to the chassis then the antiroll roll bar to the plates ,ive just ripped another arb from the chassis ,cheers
nath severs
Re: anti roll bar
nath severs wrote:hi does anyone know of any pre made and drills plates which can be welded to the chassis then the antiroll roll bar to the plates ,ive just ripped another arb from the chassis ,cheers
PRE MADE AND DRILLED that was supposed to say ?
Peter Gidden
Re: anti roll bar
Post by Peter Gidden »
Give us a bit more info.
Rev1s had a well-known issue with the chassis cracking between ARB mounting holes, but those areas were strengthened in later cars.
What Revision? What size bar? I would have thought any competent welder could strengthen the area properly for you.
nath severs
Re: anti roll bar
Peter Gidden - SBITS wrote:Give us a bit more info.
hi thanks for replying this time is was a 91 import with a gen 3 motor in it ,but ive done it with rev 2 and 3 all the same corner going up saltburn bank,the area around it is really solid ,i got told there was a strenghening plate which moved wieght to a third point on the chassis ,i was going to weld it then fit this plate if it exists lol
smartdj
Re: anti roll bar
Post by smartdj »
iv seen the plate you mean. i think it was someone like ems from the states who were doing them.
mine snapped off a few years ago due to my friend jacking the car up on my front arb mount. had it welded and its never been an issue since.
