Spigot rings?
Pidge
Spigot rings?
Post by Pidge »
This has always been a gray area for me as I don't really understand. I have just bought a new set of Inovit STVI 17"x8" @ 114.3 and wondered if I need some?
Site updated 14/04/2012
Marf
Re: Spigot rings?
Post by Marf »
The theory goes that spigot rings aid in placing the wheel perfectly central on the hub when the bore size of the alloy wheel is larger than the bore of the hub.
http://www.performancealloys.com/spigot-ring-types.aspx
Arguably the tapered wheel nuts perform the job of centralising the wheel.
What is the centre bore of the wheels you've got?
Joey
Re: Spigot rings?
Post by Joey »
I'm with Marf, the tapered wheel nuts centre the wheel making the spigot ring useless IMO
Marf
Re: Spigot rings?
Post by Marf »
Worth bearing in mind that if relying on the wheel nuts to centralise the wheel that you should do them up incrementally and jiggle the wheel before each successive tightening to ensure central fitment :)
Peter Gidden
Re: Spigot rings?
Post by Peter Gidden »
The hubcentric ring in the centre of the hub is designed to take the weight of and locate the wheel perfectly.
The wheel nuts are merely there to secure the wheel to the hub.
So there should never be a gap between the ring on the hub and the bore of the wheel.
riot68
Re: Spigot rings?
Post by riot68 »
I'm with Peter, if you run them without the rings then you'll get wobble at higher speeds, worth the money getting decent rings in my opinion...
visual anarchy since 1990...
riot68.com
Re: Spigot rings?
I wouldnt rely on tapered nuts to centralise the wheel on the hub. Spigot rings cost bu88er all and centralise the wheel perfectly on the hub.
If the wheel bore size is larger than 60.1, fit spigot rings. Simples.
riot68
Re: Spigot rings?
Post by riot68 »
I'll dig out the link I got mine from, they cost more but are metal and sprung, as Peter said they hold the weight, don't want to be trying to save £20 or £30 when it comes to keeping your wheels on...
riot68.com
riot68
Re: Spigot rings?
Post by riot68 »
Pretend this is...
riot68.com
riot68
Re: Spigot rings?
Post by riot68 »
Not here... :oops:
riot68.com
Draven
Re: Spigot rings?
Post by Draven »
treble post?? :shock:
Pidge
Re: Spigot rings?
Post by Pidge »
Cheers for the comments, I get it now. I'll measure them when I get my calipers from work tomorrow :thumleft:
Kongaroo
Re: Spigot rings?
Post by Kongaroo »
It'll be printed on a sticker attached to the inside of the alloy. The Inovits I fitted to the MX5 are 73.1mm centre bore.
I was surprised at the quality of the inovit alloys actually - they are actually decently made alloys and the tyre fitter commented on how easily they balanced, not too heavy and well priced too :thumleft:
Nic
Re: Spigot rings?
Post by Nic »
riot68
Re: Spigot rings?
Post by riot68 »
I would check with the manufacturer if its not printed on the wheel, tried measuring mine but in the end just rang OZ, better to get the right ones to start with.
Sorry on triple post too. Damn phone...
riot68.com
