starts up fine but as soon as i take my foot of the gas it stalls, if i keep the revs at 2000 to warm it up for 5 mins its ok, is this the cold start injector thats gone, or maybe cold start temp switch?
any ideas chaps
[Mk2] [NA] cold start prob
Re: [Mk2] [NA] cold start prob
This is whats been happening to mine also.
Starts up and then cuts out after a few seconds.
Ive replaced the coil pack, cold start injector relay and now going to put a new cold start injector in.![](./images/smilies/spacer.gif)
Should know by next week if it has sorted it out.
![Pray :pray:](./images/smilies/eusa_pray.gif)
Other things worth checking:
Engine temperature sensor
(can't remember which one the ECU uses to determine if cold start conditions exist
- I think water temp)
Idle control valve
- Remove throttle body to access and clean that beast out with carb cleaner.![](./images/smilies/spacer.gif)
Idle control valve
ive cleaned icv and throttle body, ![](./images/smilies/spacer.gif)
where is the cold start injector relay?
shogun666 wrote:where is the cold start injector relay?
There isn't one.
