You really do need to give it one hell of a clean and degrease before you start.
I put a bead round the whole sump rim
(why did I laugh typing that) then I used my finger to flatten it out a bit to ensure it all gets covered when it's bolted up.
Let it start to go tacky then I use a jack with some wood on to raise it up into place slowly then do opposite bolts.
Not had a leak yet on the 3sge, 3vz or.
touch wood escort cvh.
