I see three possibilities:
1.
The gasket between the motor and the gearbox was not good enough
(if generally exists such gasket
- for example by Ford that is a metal gasket against dust and some drops of water make no problems at all) and in the same time there was a leakage on top of the gearbox from the cooling system.
And it has dropped very, very long time.
2.
We don't have to forget that the condensation also exists and specially in the winter, before the gearbox became worm, the drops are going down, isn't it?
3.
There is also a hole maybe without gasket.
I don't think that you have a problem! For me it's almost normal! It will be worse if the cluch is wet!
