[Mk2] [Turbo] will a rev3 .........
swaggansway
Post by swaggansway »
will a rev 3 540 fuel rail fit in my rev 2 head?
^Trickster^
Re: [Mk2] [Turbo] will a rev3 .........
Post by ^Trickster^ »
no
swaggansway
can I get my rev2 head bored out to fit them in the future but still use my current rail with larger insulators?
I am Spartacus
Post by I am Spartacus »
the rev 3 fuel rail wont fit but the 540cc injectors should drop straight into your rev 2 rail :D
^Trickster^
no, the distances are totally different, if you want more flow you can bore the stock rail out, or buy an aftermarket, ihave a wolfkatz top feed with 1000cc injectors
Graeme
jimGTS
Post by jimGTS »
bored out rail or aftermarket is your only option aside from just dropping in the 540s into your present rail.
swaggansway
will the 540s fit in my head and rail?
I have not hot the injectors yet (next month) and am due to fit a rev2 head soon
jimGTS
Post by jimGTS »
the injectors will fit in the rail with no issues....
the injectors dont "fit" in the head, they fit in the rail, and the rail attachs to the head.....
ideally id get the rail bored tho if going for bigger injectors and more power....they suffer from pressure drop across the rail especially with an uprated fuel pump....
^Trickster^
I wouldnt put 540cc in a stock rev1/2 rail, pressure drop it pants on them and they flow crap too
Graeme
Shmed
Post by Shmed »
I had 800's in my stock rev 2 rail, and it ran fine, although I wasn't really using the 800 part of the injector. iirc they were running about 50% duty, which is about stock for a rev 2 (half of 800 :))
January 2014
..the only thing I can promise for sure is slow progress.
May 2015
just have this niggling thought that if I rip out the wiring, then the car will never get out of the garage again.
Still in the garage...
