Removal of Heater
MarkR32
Removal of Heater
Post by MarkR32 »
Afternoon all,
removing my heater and associated gummings along with it, beofre i do has anyone done this and its there / where are the pipes i need to block up
Mark
StevieL
Re: Removal of Heater
Post by StevieL »
Isn't that an MOT failure if you do this? You need a way of de-misting the windscreen. :-k
travisfububarker
Post by travisfububarker »
Once I'd taken out the heaters I rerouted one of the pipes to look like this.... Cant 100% remember what it looked like before and how I did it :clown: #-o
I THINK if you are keen you can go even further and trace those 2 connecting ends right back to the engine bay and join them there. Saving a bit more weight. I havent done that yet so not 100% sure it can be done or if its safe etc.
Once the heaters are gone you'll end up with a big gap like this in your interior....
Jonny
ashley
Post by ashley »
Definately not an MOT failure, least I've never failed for it on the other cars I've done it to...but my local MOT garage is friendly 8)
The way the pipes are routed around the engine in the engine bay makes by-passing the pipes to the matrix a doddle- I just did this on my car this evening, I'll take you some pic's tomorrow evening and post em up :thumleft:
MarkR32
Post by MarkR32 »
Awesome thank you :)
I will have a 4 inch in line blower fan installed to help de-mist the windows
ashley
Post by ashley »
Right...heater matrix by-pass:
You should recognise these pipes that go to / from the heater matrix, they run down the middle of the car above the fuel tank, AKA the hoses (or pipes) from hell:
They connect to these rubber pipes on the engine, the lower pipe then runs to a hard pipe that is bolted to the top of the gearbox:
You need to unbolt the hard pipe from the gearbox, and remove it from the rubber hose that goes round to the intake side of the engine, leaving you with this pipe- I have inserted a metal tube to act as a connector and retightened the clamp:
I have then used a spare corner section of rubber tube like this:
Remove the upper pipe from the engine (the one that didn't have the hard section on the gearbox), and use the small corner section to link from where this upper pipe was to the section that runs to the inlet side of the engine:
Job done...I've not run with it like this yet, but can't see any reason why it shouldn't be fine- if anything just a little less strain on the water pump, and less water in the car so less weight...and no pipes from hell, or heater matrix...so again less weight \:D/
monkeyra
Premium Member
Post by monkeyra »
Is it safe to assume over the past year it's not given you any problems?
SW20 Rev1 Supercharged 2GR-FE Powered Trackday Car.
Post by Martin F »
Why would anybody want to actually do this ???
monkeyra
Premium Member
Post by monkeyra »
Trackcar. A heater and aircon isn't needed.
Post by Martin F »
monkeyra wrote:Trackcar. A heater and aircon isn't needed.
But a heater would make no noticeable difference, surely it's worth keeping for a bit of warmth... :-k
Dan23
Post by Dan23 »
its all about saving weight, less stuff in the car means the car is faster
monkeyra
Premium Member
Post by monkeyra »
You'd be surprised how much weight is within all that stuff. Everyone says it weighs nothing, well they couldn't have removed theirs then. There is a fair bit of weight once everything has been taken out (controls, heater matrix, aircon matrix, the fan, all pipework etc)
Turbonoz
Post by Turbonoz »
Every little bit adds up. The heaters & associated piping are plenty of extra weight that can be lost for dedicated track & drag cars.
92 MR2 Turbo Rev2 stock engine, Link G3 TURBONOZ mapped, T78: 487bhp & 364lbft; 11.78@120. NOW BREAKING: www.imoc.co.uk/forums/viewtopic.php?p=1542658
94 GTiR: 12.08@115 TOTB Sold :(
92 300ZX: 12.6@113 (415bhp) 570bhp, 500lbft
00 Clio 172
05 WRX PPP
Dan23
Post by Dan23 »
when one of my mate took out all his AC stuff think he said ti weighed in at over 25kg, thats like a 1/3 of an average sized adult lol
ashley
Post by ashley »
I can safely confirm this has caused no issues what so ever :thumleft:
monkeyra
Premium Member
Post by monkeyra »
Thanks for confirming, I'll be doing mine this week then. What fan heater did you buy?
ashley
Post by ashley »
Can't remeber the name- it was a small german one from Vehicle Wiring Products. I'll be honest- it's not great, it does demist the screen ok- but ideally you'd probably want two of them to do the whole screen properly in mid winter...and to keep warm!
monkeyra
Premium Member
Post by monkeyra »
Ok, cheers for that. Winter is my mod/rebuild time anyway, so don't need to worry about getting cold :)
