I probably can't afford to have it done professionally as I would imagine a body shop would want to take the screen out, cut the front edge of the roof out, weld in a new piece and then respray the roof area.
So I'm contemplating taking out the top windscreen trim myself, Dremelling out the rust bubble areas, sanding down the whole leading edge of the roof back to the metal, multiple POR-15 cover to the whole area, rigid fibreglass fill the holes I will have created in the leading edge of the roof line, sand down fibreglass, filler, sand filler smooth, driveway rattle can primer and rattle can paint over the works and hope to blend in to the existing paint.
What are peoples thoughts? Does the windscreen trim have a metal insert in which I will bend when I remove it? What product would you recommend to stick the trim back down?
Any advice very welcome as thinking of tackling it this weekend.
