can anyone tell me the veriations of the HKS GT3040 turbo compared to the GT3071r i was originally planning on getting?
Pros vs Cons?
Skywalker wrote:have you looked for compressor maps? Will tell you all you need.
Gee Man wrote:Im running a hks 3037 pro-s and that made me 406bhp at 1.45 bar with 2 degs of ing timing pulled as i wanted to be extra safe on the dyno![]()
I run 1.6 on the road so no idea what its kicking out at that but its great fun..
great spool up as well.
Ryan could not belive how quick it spooled
HTH
Gee Man wrote:I was running the TD06 on standard internals at 1.2 bar for about a year then a piston ring cracked(not that u could tell as the car ran fine).
I'd done about 6 track days and 2 trip 2 the ring in that time
So I got some forge piston fitted& the gt3037 and then had a re-map
& that's it really.
The gt3037 spools quicker and has more of a hit but then I'm running more boost now so it's hard 2 put the 2 against each other.
But spool wise it's a lot quicker than the td06.
.I'll see what the new set up is like next Saturday when I do the 1/4
& handling at elvington
sjm1984 wrote:i have the oppertunity to buy a hks GT3040 turbo kit for my Rev 3 tubby to complete my forge build and have my goal of 400+ hp.
Pros vs Cons?
Spitelli wrote:sjm1984 wrote:i have the oppertunity to buy a hks GT3040 turbo kit for my Rev 3 tubby to complete my forge build and have my goal of 400+ hp.
Pros vs Cons?
I run a GT30/40 but only have my old Greddy T67 to compare it too..
This Hybrid is essentially a GT30 Turbine with a GT35R Compresser..
I have a link somewhere that has the tech data.
Will dig it out but not sure if it will help with the HKS stuff? Let's see
sjm1984 wrote:From what i can gather the GT3040 is inbetween the GT3071& GT3076
Gee Man wrote:Soooooooooooooo jj the question is
When are you slapping a blower on your BMW
sjm1984 wrote:jj Thanks for the Info
I think i'll go for the Gt3071 kit instead as the Gt3040 is more than what i need from a turbo just to give me 420hp
sjm1984 wrote:Just to run your normal momentum 99(tesco) or V-power.
it will be driven on the weekends only as i have a daily VW polo and i work in the city.
420ish fly running wolfkatz 870 kit should be enough fuel?
