92 GTS T-top REV 3 conversion Factory LSD
PW/PDL/Turning fogs
Approx 117k miles on car
MOT until Sept 2010.
Taxed until Feb 2011
Car is in good condition overall with no major body damage, paint work is in pretty good condition for its age and polishes up well.
Interior in very good shape, recently replaced door lever bezels, door switch bezels and ash tray.
Drivers seat bottom has a small section where the stitching has been worn and the bolster shows usual wear.
Car has been gargaged the entire time I have owned it and I believe the prior owner garaged it all the time.
Regular oil/filter changes.
Will include new NGK plugs and new in box front/rear OEM brake pads.
Recently replaced drivers window regulator and drivers body side t-top seals.
I have access to a car lift and buyers can inspect the car if desired
At approx 90k miles the following was performed:
Headgasket replaced, with a 1mm cometic multilayed STEEL headgasket.
ARP head studs
New idler bearings, new cambelt, new turbo and head/block gaskets
New 13ltrs werth of forlife coolent
New hose from hell installed, new thermostat, new oil cooler gaskets.
Then comes the head!
Fully cleaned, skimmed, relapped, reshimmed to take a rev3 inlet camshaft, new cam seals, new valve stem seals.
Fully cleaned and painted engine bay.
Removed TVIS and TVSV components
Full speed density conversion
Was previously mapped on a Apexi Power FC running 301.4bhp, 290lb of torque at 1.2bar.
Ct20b, very little shaft play, done I believe around 80k miles.
Apexi filter, extremeboost downpipe
HKS exhaust
Walbro 255 fuel pump
Greddy IC with one piece Berk cold pipe, Berk hump hoses.
Greddy Profec Spec B boost controller
Painted engine bay with red hoses
Rota slipstream, 7.5 and 8.5 staggered setup, running on toyo T1Rs tyres, all plenty of life left in there, 215/40 and 245/40.
pi
Rtock struts front and Tokico adjustables in the rear
Greddy copy skirts and front lip from rogue systems
Rev5 OEM sidelights
Rev2 lights with full 4 lightup mod.
FULLY colour coded sidestripes and T-bar edges
Momo wheel, leather seats and door panels.
A pager LEA 826 alarm, remote start, remote headlight, turbo timer.
bonnet, boot, door sensors
The bad bit.
Loads of info from prior owner: http://www.imoc.co.uk/forums/viewtopic.php?t=98859
Recent pics
![Image](http://i152.photobucket.com/albums/s182/86AW11/1992%20MKII%20Turbo/100_0409.jpg)
![Image](http://i152.photobucket.com/albums/s182/86AW11/1992%20MKII%20Turbo/100_0410.jpg)
![Image](http://i152.photobucket.com/albums/s182/86AW11/1992%20MKII%20Turbo/100_0413.jpg)
![Image](http://i152.photobucket.com/albums/s182/86AW11/1992%20MKII%20Turbo/100_0415.jpg)
![Image](http://i152.photobucket.com/albums/s182/86AW11/1992%20MKII%20Turbo/100_0418.jpg)
![Image](http://i152.photobucket.com/albums/s182/86AW11/1992%20MKII%20Turbo/100_0421.jpg)
