After Market Steering Wheel Horn Help.
Retro_Boy_G
Post by Retro_Boy_G »
Hey guys,
I've received my boss kit today to fit my new steering wheel but I'm having problems getting the horn button to work.
The boss kit comes with a wire that I'm guessing is grounded via the boss kit which touches the steering wheel thread.
Can anyone tell me if they have had similar problems and managed to fix them and also, does the horn work when the ignition is off?
Thanks!
Gianni
aw11rally
Re: After Market Steering Wheel Horn Help.
Post by aw11rally »
I had a similar problem.
The horn button is held into the wheel by a couple of springs clips, these also provide the earth when the horn is pushed. To get mine to work I had to remove the paint off the inside of the appature in the wheel so that the spring clips made a good contact. No problems since.
Give it a go.
PW@Woodsport
Post by PW@Woodsport »
I gave you the solution on the Mk1 club forum.
Retro_Boy_G
Thanks dude, I'll go have a look :)
Gianni
matt86
Post by matt86 »
Thread revival here, but has anyone got any experience with the boss kit that paulsims sells on eBay?
Have just started fitting it, and I'm having an issue with the interface between the boss and the little (brass) spring loaded connection in the steering column for the horn! Let me know asap as I want to fit my new OMP wheel!
elbon50
Post by elbon50 »
I seem to have a similar problem to you with a Paul Simms S/W boss Matt
It seems that the little brass brush doesn't reach to the circular plate on the boss
Havn't found the answer to the problem yet
Another problem is that the indicators don't cancel with that boss fitted
Peter
matt86
Post by matt86 »
No the indicators won't cancel - the underside of the boss does not match the standard steering wheel- so therefore the kit is not a mk1 mr2 compatible kit as advertised. Have contacted the seller, waiting to hear back from him. I'm going to see if I can return it, if not it will be a matter of modifying the boss... I'll let you know what I find out
un1eash
Post by un1eash »
Hi Matt, got your PM. I still have my Momo boss but was trying to sell it with the wheel. Over the years the answer seems to be the momo 7714 boss is the only one that fits perfect and has no issues with space and indicator cancelling.
Retro_Boy_G
I never did get mines working.. I always put it down to the spacer I had to fit so my fingers didn't hit the indicators.. Hopefully at my next MOT the guys will get it all wired up.
elbon50
Post by elbon50 »
matt86 wrote:No the indicators won't cancel - the underside of the boss does not match the standard steering wheel- so therefore the kit is not a mk1 mr2 compatible kit as advertised. Have contacted the seller, waiting to hear back from him. I'm going to see if I can return it, if not it will be a matter of modifying the boss... I'll let you know what I find out
Do you still have the box that the kit came in Matt ?
On mine is written "Max II Steering Boss Kit Universal Type"
Then iin a little white panel is printed "T-12 TOYOTA"
Seems a bit of a contradiction stating universal & then Toyota
MR2 is not mentioned
Peter
Clarky_X
Post by Clarky_X »
I use Momo Boss and wheel and extension adapter and all works fine.
I had lots of problems with the momo boss not working properly initially because it kept going too far down the steering column and crushing the purple plastic indicator ring with the studs that go into the back of the boss.
The only solution was to replace the steering column because the threaded end was all a bit mangled, didn't look obvious, but the threads weren't nice and clean. When I put another column in, the Momo boss fitted perfect and everything worked.
You have to have a silver ring that goes inside the steering wheel to make the horn push fit tight, otherwise it just drops straight out.
The extender that I got with the Momo boss kit fits on the steering wheel side of the boss so doesn't interfere with anything on the column side and is just a 15 mm ring and 6 longer allen bolts to reach through the extender into the boss.
Like I say, it all works fine. It was an expensive upgrade though.
Something like £200 for the Momo 350mm suede wheel another £70 ish for the boss and another £15 for the extender.
But I prefer the wheel to the old one and the previous boss was a home brew affair and wouldn't work with the new wheel.
matt86
Post by matt86 »
Peter
Sounds like the same boss that I got from memory. I returned it and got a full refund from Paul, he did this fairly quickly with no fuss :)
Godd luck!
elbon50
Post by elbon50 »
Thanks Matt. Will contact Paul & see what he says
It may be suitable for a Toyota but not for a MR2 Mk1
The horn contact ring and the holes for the signal cancel ring to register in are wrongly sized/spaced
Peter
User avatar
Lauren
Post by Lauren »
Don't bother messing about with tat off ebay, just get a momo boss. Sorted. :+:
kevin..in
Post by kevin..in »
Lauren wrote:Don't bother messing about with tat off ebay, just get a momo boss. Sorted. :+:
ask what the no. is on this as the early MK2 MR2 uses the same boss as the MK1 you're looking for code L7714
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
kevin..in
Post by kevin..in »
clicked wrong button :roll:
elbon50
Post by elbon50 »
Thanks for that Kevin
Have asked the question
Peter
elbon50
Post by elbon50 »
Its C7728 Kevin
Peter
kevin..in
Post by kevin..in »
elbon50 wrote:Its C7728 Kevin
Peter
nope no good then, new one from momo is about £50ish delivered
un1eash
Post by un1eash »
7714 is the momo boss for the mk1. I have one for sale with a OMP Super Quadro 320mm D shape steering wheel.
